Doing an insert/update with a single dropdown list
Thread begun 1/29/2010 8:07 am by david.barrack304604 | Last modified 1/29/2010 2:18 pm by Jimmy Wu | 2656 views | 3 replies |
david.barrack304604
I want to use a dropdown list where many selections can be made, and then need to insert/update the database with the selections. Does the DD extension help with this? I know the extension is geared towards 2 or more lists that are connected but not sure if the update/insert feature is also there and could be used for the 1 dropdown list case.
If not, where should I look for doing this besides coding it? The example is giving a guest a list of amenities they would like which they can check off (ie, hair drier, bottled water, etc.).
Jimmy Wu
Dynamic dropdowns is for helping you populate the next dropdown list dynamically based on what is selected in the previous list, not for helping to multiselect dropdown items. If you have a list of items and want to insert the selected ones into a database, I would suggest using checkboxes to insert these. We do not have a tool that inserts a multiselect list and inserts the selected values into a database.
david.barrack304604
Hi Jimmy,
The problem though is the list of items is dynamic. So I don't think a dynamic list of checkboxes can be created (or least not created easily). What do you think?
Jimmy Wu
A dynamic list of checkboxes can be created within a repeat region, and populated with the information from a recordset.
