not working!
Thread begun 2/01/2010 10:42 pm by argess.productions | Last modified 2/03/2010 6:09 pm by Eric Mittman | 2646 views | 3 replies |
argess.productions
not working!
i'm running DW CS4 on Windows XP and have tried to get this to work in both the version 2 and version 3 programs; i've established a site definition with an index.htm page created and open, then have tried starting a new SiteAssist site. the dialogue box that pops up is shown in the image attached.
as the image shows, there's no "next" or "continue" button. i fill in the available info and then what can i do? i press enter and the dialogue box disappears and nothing happens... no siteAssist site created.
What are the resolution and DPI settings for your display? I know if you have too small of a resolution or if the DPI is too high you can experience issues within the interfaces like this. A resolution of 1024x768 and a DPI of 92 are the best settings to view the interfaces.
argess.productions
screen resolution...
my screen resolution is set to 1280x600 and the only other alternative is 800x600 which produces the same result. i have no problems with menus displaying in any other programs. perhaps if the "next" or "continue" buttons could be given priority over the ad at the bottom of the menu... it might not be such a problem? i'm really unhappy with having all the popups and built-in ads that webassist and dmxzone include within dreamweaver programs...
It is your screen resolution that is limiting the display, you have only 600 vertical pixels, you need to have a minimum of 768.
Even if you did not have the add in the first screen you would still have this problem as the entire size of the interface is used by the other screens in the wizard, we did not create the space to put the add in, we just made use of space that would not be doing anything else.
