Trying to join the order table and order detail together on the detail page
Thread begun 2/03/2010 11:50 am by sturgisk383938 | Last modified 2/04/2010 9:51 am by Mustapha307688 | 3059 views | 3 replies |
sturgisk383938
I trying to create an order history and detail page to my site. When I test the pages I can get the history page to display information but when I click the link to see the detail page. I get an sql sytax error was is, You have an error in your SQL syntax; check the manual that corresponds to your MYSQL server version for the right syntax to use near 'FROM orders INNER JOIN -1 ON orders.OrdersID = -1.DetailOrdersID WHERE -1.DetailO' at line 1.
I have followed the instruction posted on your web site regarding how to create an order history page. I tried to change the WADAorderdetails server behavior for the detail page.
I entered the code to join the orders and ordersdetails tables as follows:
SELECT orders.*, orderdetails.*
FROM orders INNER JOIN orderdetails ON orders.OrderID = orderdetails.DetailsOrderID
WHERE orderdetails.DetailOrderID = WADAOrderID AND order.OrderUserID = paramUserID
I did add the variable parameter paramUserID. My question is for the first variable parameter was colname. What should the first variable name be? What did I do wrong?
Help?
judging by the error, it looks one of the parameters you created was named "orderdetails"
when naming a parameter, I always preface the name with "param", for example, "paramOrderdetails"
sturgisk383938
still having problems with the history page and detail page
I have read the how to create an order history page several times and retrace my steps.
I am still having problems with this. My problems is customize the order detail page. According to the direction the Server Behaviors WADAorderdetails needs to be change.
I have modified the entire SQL statement. I also add another variable parameter for paramUserID. My questions is what should be the first parameter when you modified the SQL statement. I am confused regarding this. The SQL statement looks like this:
FROM orders INNER JOIN orderdetails ON orders.OrderID = orderdetails.Details.Details.DetailOrderID
WHERE orderdetails.DetailsOrderID = WADAOrderID and order.OrderUserID = paramUserID
This is in the how to create an order history tutorial. I also have applied the Login/Registration as well. What should I do next? I really want this to be part of the site.
Mustapha307688
Join statement might not be correct !
Hi there
I am asuming you are using dreamweaver and you are connecting to a mysql database.
i do not know what you database erd and structure looks like but looking at your join statement I noticed this:
"SELECT orders.*, orderdetails.*
FROM orders INNER JOIN orderdetails ON orders.OrderID = orderdetails.DetailsOrderID"
1. You joining primary Key with primary key of another table !Wrong !
2. I think you should try to clean up your statement to look like this below.
Select * from Orders INNER JOIN OrderDetails ON
orders.OrderID = orderdetails.OrderID (you could also leave out INNER for now)
Leave out the where clause for now just to get your join to work !!!
Now what I would reccomend is open dreamweaver ...
1. Create a connection.
2. Create a recordset and in the dialogue copy and paste the join statement that I gave you ***INTO THE SQL TEXT BOX THAT IS THERE ***and click test ! If it works then you will actually see all the fields in both tables ...! Else it will tell you that you have a syntax error.
If that is the case I suggest you examine your ERD carefully to see that the PK OrderId is actullay refencing the OrderDetails Table as ForeignKey !
I hope this will be of some help !!! Let me know !
Mustapha
