While executing onChange in WA eCart
Thread begun 2/05/2010 7:21 am by jegoadby285710 | Last modified 2/25/2010 2:31 pm by Eric Mittman | 7092 views | 15 replies |
jegoadby285710
I get this error when trying to assign a dynamic product id.
Iv attached an image file of the error.
Im using CS4 on a Intel Mac.
Any help is greatly received.
Kind regards
John
Dani Chankhour
I have attached a zip folder, please download and extract the zip to this location
Hard disk: Users: [User Name]: Library: Application Support: Adobe: Dreamweaver CS4: en_US: Configuration: Commands
Make sure to have DW closed and delete the cache file before restarting DW.
146/
jegoadby285710
error on search results page
Hi
Thank you for the fix that seems to have sorted that problem out. Unfortunately I'm now getting this error which looks as if some component id missing of the server but i have defiantly uploaded the eCart directory.
Iv attached the page in question and a screen shot of the problem.
Fatal error: Call to a member function on a non-object in D:\Webs\electionequipment.com\wwwroot\searchresults.php on line 3
As ever any help is most gratefully received.
Kind regards
John
Dani Chankhour
It seems you are missing an include file at the top of the page:
At the end of line 1, press enter and paste this code:
//WA eCart Include
require_once("WA_eCart/Electrol_PHP.php");
jegoadby285710
Lost image in shopping cart
Thank you again for you help with this cart (its the first time iv used it but its very easy to use).
Can you just give me a few tips on how i can make sure i get my images passed to the cart please.
Kind regards
John
Iv sorted this now, It was pulling the wrong info from the data base. but i did have to manually alter the code the application did not alter the code is there a reason for this? It would help me if I understood why it was not editing the code properly its the add to cart part of the application in the bindings section that does not seem to work. But all the rest seems fab.
Kind regards
John
Jimmy Wu
Sometimes a field is not updated correctly in the interface unless you click into the field and hit enter and/or tab. If a value isn't getting updated correctly you should try that.
blackweldermhe400113
While executing onChange in WA eCart AddToCart.htm a javascript error occurred.
Originally Said By: jegoadby285710
Kind regards
John
I'm having the same problem, but I'm using a PC with CS3. Should I use the same zip file and extract the file to this location, Adobe: Dreamweaver CS4: en_US: Configuration: Commands, as posted above?
I'm just trying to change the recordset that the Add to Cart button is referencing when I get the error.
If the error is the exact same you can try moving the js file into the proper location, before you do this though you should rename the old one so that it is backed up in case this is not the fix for you. Here are the paths for xp and vista/7.
xp
-DWCS3
--C:\Documents and Settings\<Your User Name>\Application Data\Adobe\Dreamweaver 9\Configuration\Commands
-DWCS4
--C:\Documents and Settings\<Your User Name>\Application Data\Adobe\Dreamweaver CS4\en_US\Configuration\Commands
vista/7
-DWCS3
--C:Users\<Your User Name>\AppData\Roaming\Adobe\Dreamweaver 9\Configuration\Commands
-DWCS4
--C:\Users\<Your User Name>\AppData\Roaming\Adobe\Dreamweaver CS4\en_US\Configuration\Commands
Problem with the id_product parameter being passed when eCart is present.
Some of the problems that I've had with this project were already solved with the help of the webassist staff in some other threads.
showthread.php?t=9916&page=2
First, let me start by saying that I have a products page pulling records from a recordset that has a WHERE statement saved inside of a session variable with two conditions separated by and OR. Each record had a "Find out more" button that passed an id_product url parameter to a products results page that would show a more detailed oriented entry for that product. It was working as it was supposed to before applying the eCart object along with the add to cart button, but when the eCart object and add are present the screen goes white and wont filter properly from the products page. Any ideas as to why this is happening? I tried just removing the add to cart button to narrow the problem down, but it also happens if it's just the eCart object that is present. I've attached my php files for both the products.php page and the productsResults.php page.
When a php page comes up blank it usually means that there is an error on the page and you will need to enable error reporting to see it. [You can try to enable the error reporting yourself by using this code at the top of your pages:
error_reporting
(E_ALL);
Please give this a try and let us know the result.
