Update 2.04 destroys DMX extensions :-(
Thread begun 12/03/2011 6:16 am by Cologne | Last modified 4/20/2012 1:17 pm by Jason Byrnes | 10179 views | 12 replies |
Cologne
since I installed the update to 2.04 my DMXZone extensions dont work anymore.
When I deinstall SA2.04 everything works fine again.
Please fix that problem.
Where can I download the previous version ???
Cheers
Denis
Cologne
Hey Jason,
thats no good idea, cause i dont want do install the SA2.04 again, cause, it causes me lots of trouble, with install, deinstall and reinstall, about 20 extensions.
maybe you can send me the version before 2.04, cause that worked.
cheers
denis
i have updated your ticket with a link to version 2.0.3, if you would like us to fix the problem in 2.0.4, however, we will need to work with you in a connect session to troubleshoot the cause of the issue.
MikeH
Hi
If Im not mistaken this is caused by the client side validations toolkit. If you remove that the behaiour connector works fine. As the client side are pretty much no use nowadays this will solve your issue.
Sorry Jason for joiing in but Ray went through this with me and located that. :)
Mike
Cologne
How can I do this?
I tried to install ther 2.03 same error. Same with the 1.19 version. And now I get tons of JS Errors, 20 times I open DW.
I got that formBuilder and cannot delete the client validation itself, or can I?
I cant belive that this is not fixed. insted of putting all the extensions into one, make them work fine on their own.
Please Mike, where can I delete the validation?
Its also nice to hear, that they know the error but dont FIX it!
cheers,
Denis
Cologne
In my opinion the BIGGEST problem is, that you need to knwo, in which order you have to install the extensions.
I got nearly all WA extensions, and there ist, form tool kit, security assist AND the form builder that got validation included.
the thing is, I need to bought the tool kit, to get the captcha thing.
When you installt SA204 first and then data assist, you have the OLD UI. when you install the Form tool kit, then suddenly the new UI is there but the unique data validation is missing.
thats, so,aaarg, i cant tell.
maybe, you put out an order, what to installt first. this will save lots off time.
thank you!
for the most part, there is no order, with the exception of installing these extensions last
Form Toolkit
CSS Form Builder (Make sure to use the 2.0.1 support release 2 version)
HTMLEditor 3
Security Assist 2
MikeH
Hi
This issue seems to have raised its head again.
Now I do not have the original offending extension "client validations" installed anymore.
I do however have
the latest
Security Assist
form Toolkit
CSS formbuilder
My guess is one of these as its the exact same issue which really isnt good at all.
I did uninstall Validations for Spry but that didnt make any difference.
Any ideas Ray or Jason?
Regards
Mike
Ive since found it seems to be CSS From Builder related. Any ideas how to fix this without the need to remove and not use form builder?
MikeH
Ive since disabled FB and then re-enabled it to find that seems to have solved the issue.
Mike
