Ecart 4.52 Object
Thread begun 1/15/2010 10:17 am by cyberdriveuk194445 | Last modified 1/19/2010 11:52 am by Jason Byrnes | 2679 views | 7 replies |
cyberdriveuk194445
Ecart 4.52 Object
I upgraded & installed to the latest ecart 4.52 now when I add a buy button it states there is no Ecart object however there is an ecart object from the previous version what should I do
to rectify this issue.
Is the page you are trying to add the Add to cart button saved to the same Dreamweaver Site as the previously created eCart object? The eCart object and the add to cart page must be members of the same Dreamweaver site.
cyberdriveuk194445
ecart object
yes is the same site & same page its as if the new version does not recognise that there is an ecart object there from the previous version that is why it is asking to insert an object first.
is the WA_eCart folder at the root of the site?
Is the new page you are adding the add to cart button to the same type of Dynamic page. In other words, if you created a PHP cart object, you will not be able to add it to an ASP page.
cyberdriveuk194445
ecart object
it is not only the same type of page it is an exisisting page that already had buy buttons on it already I want to add more buy buttons however it is stating I need to add an ecart object first its as if it does not reconise the previous version. please help
cyberdriveuk194445
ecart object
the problem I also think may be that the new operation system is windows 7 could this be why ecart is not recognising why there is already an ecart object there from the previous version.
I have created a support ticket so we can look into this issue further. To view and edit your support ticket, please log into your support history:
login.php
I have created a support ticket so we can look into this in more detail. to view and edit your support ticket, please log into your support history:
