WA_eCart/WA_eCart_Database_PHP.php error on checkout page
Thread begun 4/23/2020 1:47 am by georgina_barrett_187762 | Last modified 4/23/2020 12:26 pm by Ray Borduin | 742 views | 3 replies |
I have just purchased ecart and am trying to set up my first shop. I created an eCart object and then used the checkout wizard to create the shop. I am using a database and downloaded the tutorial tables given when you download the software. The cart has been created correctly but when I go to the checkout page I get this error (after adding the error script code)
Warning: require_once(../WA_eCart/WA_eCart_Database_PHP.php): failed to open stream: No such file or directory in /home/benidormcd/public_html/en/confirm.php on line 50
Fatal error: require_once(): Failed opening required '../WA_eCart/WA_eCart_Database_PHP.php' (include_path='.:/opt/cpanel/ea-php56/root/usr/share/pear') in /home/benidormcd/public_html/en/confirm.php on line 50
I have checked and I don't even have the file WA_eCart_Database_PHP.php in the folder WA_eCart. How do I get it?
Can you attach the page? I think if you are using MySQLi that page isn't used anymore. You may be able to delete the reference to it instead of tracking down the page.
Thank you. Here you go. I am using MySQLi.
Just delete the reference to that file on confirm.php on line 50. I'm assuming it is using MySQLi as well. That is the page I actually had to look at to confirm.
