which behaviors use the wa_appbuilder_php.php library file?
Thread begun 12/27/2021 1:37 pm by TroyD | Last modified 12/28/2021 12:03 pm by Ray Borduin | 1202 views | 2 replies |
TroyD
I am cleaning up several depreciated warnings in my websites and in the case of the "PHP Deprecated: Methods with the same name as their class will not be constructors..." warning, I usually first try to regenerate new library files just in case there are companion files that also get updated.
In the case of the database_management/wa_appbuilder_php.php file I'm having trouble getting it to recreate the new file when I delete it. Which behaviors generate that file?
I'm wondering if the wa_appbuilder_php.php file is even needed anymore in SOME cases. Maybe it's left over from old behaviors I have since removed. But in some sites, I'm sure it is still needed and I want to make sure it's updated.
While I'm at it, when and where that library file is still needed, can I just change lines 124 and 167 to use __construct in place of the function name?
Thanks,
TroyD
That is used for the old MySQL insert, update, and delete server behaviors. It can be deleted if you have migrated to mySQLi.
Yes, you can update the constructor manually to address the message where the functions are still needed.
TroyD
Thanks Ray!
