Upgraded to Snow Leopard and now can't make a database connection
Thread begun 1/05/2010 9:04 am by wilyumcj205276 | Last modified 1/23/2010 8:12 pm by wilyumcj205276 | 4143 views | 16 replies |
wilyumcj205276
I upgraded to Snow Leopard and now I can not make a mysql database connection(php) I get HTTP error 404 file not found. The testing server specified for this site does not map to the ~william:Sites:
Web sharing (system preferences) says my personal website address is ~william/
Do I need to change my personal address to 127.0.0.1 ?
No. In the Dreamweaver site definition, go to the testing server tab. set the URL Prefix to:
~william/
wilyumcj205276
I tried that before I started the thread. It did not work. So I downloaded and configured MAMP. When I tried this connection it said I was using the wrong socket which is /tmp/mysql.sock. Now I'm trying to change the socket to var.......etc by using text editor to reconfigure the etc/my.cnf . Which is what I had to do the first time. But I can't find the file using Textwrangler. ANy suggestions? Thanks
wilyumcj205276
Mamp disables GUI tools MySql Query Browser, so I don't want to use Mamp, because I'm use to using GUI tools. Unless MAMP is the best way to go in the future to be able use CMS like Joomla, or Drupal. I'm not even sure what they do, but I keep hearing about them. Can we do a screen sharing session to fix this issue?
I still keep getting error 404, even when I use http:/10.0.1.2/~william/
wilyumcj205276
DWCS3 keeps giving me 2 identical error message pages. There are 2 instances of mysql in my system preferences. Could this be a problem.
In the connection dialog page do I need to use 10.0.1.2 instead of localhost.(I've tried both ways) I use root for username, and my admin password
it sounds like you have 2 different webserver on the computer at the same time, and they are conflicting with each other.
only one webserver can be running at a time.
wilyumcj205276
I deleted the other instance of Mysql in my system. It was the Mysql Preference Pane. Still no database connection. I notice that when I turn off my airport internet, the personal address goes back to ~william/ . I used this for new site definition, and still no connection. I'm really stumped,because I only made about 100 database connections before reinstalling all of this "same" software. I did a timetest.php, and php showed the correct time in browser. When I try to view php pages from dreamweaver cs3 I get Not Found The requested URL /~william:Sites:one/Untitled-1.php was not found on this server. This should be a clue as to some piece of the puzzle is missing. Mysql is on, php is working. Apache has to be working for Php to be enabled .......right? Thanks for your help
Wiliam
What are the settings in your Dreamweaver site?
Can you post screen shots of the local info and testing server panel of the site definition?
You will probably need to compress them into a zip file and attach the zip file to send viewable images.
garry.bradley337443
Did this come to anything Jason? I've got a similar problem in a new thread (Very simple Mac localhost problem), my server is running fine though using MAMP.
Can't seem to get the path right to my localhost though.
wilyumcj205276
screen shots
Sorry it took me so long, but I had to go on a business trip. Here are the screen shots you requested. It seems someone else has the same problem. Did they resolve it? Thanks!
William
